This is pretty much the expected result for non-Doppler static object detection, so all is good. Next task is to get this waveform into a RPi via an ADC without turning it into toast. Some lowering of the voltage and removal of DC offset may be required. Then, a bit of Fourier transform magick to pull out the hidden frequency and amplitude elelments.
