Diagnosing range issues
A project log for Radar Sensor
This project will be using an InnoSent IPM 165C and / or IVS 362 module to sense distance and motion towards / away from the observer.
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 05/27/2021 at 10:390 Comments
Apparently the IVS-362 should have a range of 20m, so something is wrong!
These are some oscilloscope screenshots with the signal generator set to 200Hz with a voltage amplitude of 2.7 volts:
Channel IF1:
Channel IF2:
These readings were taken in a cluttered indoor environment with plenty of reflective objects in the 3 to 5 m range. But the module does not seem to be very responsive.
