Kalman filters are overkill?
A project log for dayTime
sync your microcontroller to the diurnal cycle using sensor data
simon-merrettSimon Merrett 04/24/2021 at 18:500 Comments
I saved this for a separate log because I would like to return to this topic once I have brought the rest of the project up to date.
Kalman filters are well known and regarded for their ability to quickly adapt state estimations (ie the filter output) to legitimate signal, amongst noise. I had been wondering about this for some time when I posted a .stack entry to solicit input from the community over a year ago:
https://hackaday.io/page/6902-is-a-1d-kalman-filter-suitable-to-correct-clock-drift-against-an-external-noisy-cyclical-phenomenon
For now, I will leave you with that exchange of thoughts and promise that I will return to the topic - when I do, any further wisdom from you in the comments here would be most welcome!
