Hackaday.io Hackaday.io
Sign up Log in
Twister Mat MIDI Controller
Discreetly modifying an old Twister mat to transmit MIDI note events when the circles are touched.
guy-dupontGuy Dupont
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
447
3
0
3
Team (1)
  • guy-dupontGuy Dupont
Join this project's team
  • Twister Mat Source
hardware
ongoing project
midi ESP-32 TWISTER
This project was created on 04/24/2021 and last updated 5 years ago.
Description
Using 24 force-sensitive resistors, some ADCs, and an ESP-32, I've built a Bluetooth MIDI controller from an old Twister mat. The hardware is all battery powered and protected by a wooden case, so the mat can safely be placed close to falling bodies but far away from any expensive noise-making equipment. See full build video in project details, and check the Github page for source code (coming soon).
Details
Components
  • 24 × Force Sensitive Resistor One for each colored circle. I used ones with a 1.5" square target area.
  • 24 × 1k ohm Resistor To create voltage dividers with each FSR
  • 3 × MCP3008 (8 channel, SPI ADC) 3 X 8 channels == 1 channel per FSR
  • 1 × ESP-32 Dev Board Any should work, but you'll need access to default SPI pins + 3 Chip select pins (I think you can use any GPIO for these)
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Jonny wrote 03/07/2024 at 12:53 • point
Struggling to source components, and manage the influx of ludicrous¿? Ideas , like (newest) multi (controller) surface modes, ala osc/midi interfaces, to add tempo +/- , MTP, an X,Y floor sensor surface 📌, and a matrix, like a scale stepper https://sequencer.henryfellerhoff.com/ trying to order something like this https://www.alibaba.com/showroom/mcp3008.html whilst (always:) learning everything I need to know, and source . which is pretty much everything!
Dan Maloney wrote 04/27/2021 at 17:16 • point
Brings back memories of Twister tournaments when I was in college. Don't think they're doing that these days!
Guy Dupont wrote 04/27/2021 at 17:17 • point
Definitely not this year!! Tournaments though?! that sounds awesome.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Twister Mat MIDI Controller", please tell us the reason.
Send message
Remove Member
