Block Diagram
A project log for PiBoy 64
A Raspberry Pi Compute module based emulator inside of a GameBoy advanced
matthew-carlsonMatthew Carlson 05/26/2017 at 22:530 Comments
I think I'm going back to the drawing board a bit to add some more features. I decided wifi is a must have feature or at least in the future. I also need to figure out battery power issues since I don't know if my chosen battery will be able to do 1.3-1.5A peak much less the .9amps under load. Here's the overall block diagram:
