Replace broken CCFL backlight on laptop with LEDs
DC/DC-converter and SMD-LEDs instead of CCFL inverter an tube
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
As the CCFL backlight on my IBM Tinkpad T20 broke some years ago in 2010, I had to find a cheap solution to repair (I was a student at that time). As it was not clear whether the inverter or the tube was defective, I decided to replace the whole backlight with some SMD-LEDs laying around. I also had a DC/DC-converter (LDO03C-005W05-SJ) from an old project, so that I only had to make a appropriate pcb to solder LEDs and resistors on. The pcb had the same dimensions like the CCFL-tube so it could easily be replaced. The result was quite ok, as you can see on the pics.
