Laser sensor for filament on 3D printer
Compare the movement of motor to the movement of the filament to detect clogged
Compare the movement of motor to the movement of the filament to detect clogged and runout.
if it detect the clog or runout,it will set the output signal line to zero voltage which tell the mother board to pause printing.
it works with all other motherboard which have run out connector.
runout and clog test of laser filament sensor
,with the micro USB  you can get the raw data of the sensor and motor, update the mcu firmware, set sensitive value.
so it works with all other motherboard which have run out connector
Standard Tesselated Geometry - 65.12 kB - 05/12/2021 at 08:16
Download
Adobe Portable Document Format - 597.02 kB - 05/12/2021 at 08:12
Preview
Download
Adobe Portable Document Format - 782.38 kB - 05/05/2021 at 09:43
Preview
Download
View all 2 project logs
