BitPiRat Computer (GEN1)
First in the world dedicated RPi platform for full node bitcoin (BTC) and Lightning Network
BitPiRat Computer (GEN1) This is a dedicated, first in the world, tiny, compact platform for cryptocurrency networks, such as for bitcoin nodes (RunCitadel, RaspiBlitz) or as microserver. Technical specification: - RPi Pi Compute Module 4 (CM4), - full 2280 M.2 M-key socket dedicated for NVMe PCIe disk drives (1TB size or more), - microSD card slot, - GbE RJ45 port, - 2x USB 2.0 ports, - USB-C (USB 2.0) for CM4 flashing, - 5V power rail with up to 5A power delivery, - dedicated power supply connector (2-pin terminal block), - 2-pin fan socket for simple 5VDC fans, - HDMI type A video output, - slide switch for boot/flash mode. This is only GEN1. The GEN2 will have (probably): - optional PoE support (power supply), - M.2 socket placed on the bottom side (more compact design), - 12VDC input and dedicated buck regulator, - only passive cooling.
There is no GPIO, UART, I2C pin headers. No audio, PoE support.
View all 4 project logs
