Rev 4
06/28/2021 at 21:58 • 0 commentsBased on user feedback, I added a focus picture that fades in and out when the slide is changing. This allows freestyle viewers (eyes only, no VR box) to not loose focus. I also transition the slides every 10 seconds instead of 7. Results are good so far.
Updated slide positioner
06/28/2021 at 21:54 • 0 commentsReally cool update that I'm super happy about. Sometimes the slide would be just outside the camera view. I added code for the camera image to adjust the slide position so it is center of the camera view. It is really neat to see it work, the image slowly moves the slide up or down to get into the center.
When the image switches to threshold mode, (white and black) you can see the slide adjust to center.
Multiple revisions over 6 months
05/07/2021 at 23:45 • 0 commentsI've been working on this project since December of 2020. It took me a while to get it to a point that I was satisfied with. Currently, I am on version 3.
Version 1: random music and using ring LED with no light diffusion.
Version 2: using ring LED with light diffusion and adjusted the size of the images and spacing
Version 3: switched to Jewel LED for more even lighting, switched to DaVinci Resolve video template.
W. Jason Altice
