First look at the PA
A project log for Simple Digital Mode Transmitter
A low-power, all-digital transmitter.
robgRobG 06/17/2021 at 16:390 Comments
Was in the office today so had a chance to run up the PA on the bench. Having first carefully set the MOSFET bias so that each was passing something like 25mA (according to instructions here), I could then adjust the drive levels to get a nominal 10W out. Then, sweeping the frequency in bands (4-8, 8-16 and 16-32MHz) the plot below shows how the output looks, including harmonics:
PA output, whilst frequency is swept - max hold on.
Clearly the output power isn't very flat, but conveniently for me it peaks at about 14MHz (20m band) which is where I was intending to use it most. Third harmonic is the worst offender, at about 23dB down, so a filter is required on the output - no surprises there. Would be good to get the 2nd harmonic from -33dBc down to <-43dBc, so then I'd only need a single LP filter (with corner=28MHz) to cover all the bands from 20m to 10m and still meet "the -43dBc requirement"*. Will see if I can tweak the MOSFET biases to achieve that.
The real shocker was the drive level required: only -27dBm! (at 14MHz). I might just bypass the first stage as I definitely don't need all that gain...
Lastly, this: (14MHz, 12V supply)
Pout (W)last stage current (A)Efficiency (%)
10.7411
21.0915
51.7524
102.5333
I'm hoping a simple moving-coil ammeter on the PA supply will be enough to give me a rough idea of output power.
*interesting that the UK requirements seem to be much more relaxed: "...as free from Unwanted Emissions as the state of technical development for amateur radio apparatus reasonably permits"
