Additional advantage
A project log for Anteneh's Ventilation against COVID-19
This project is about building a new kind of ventilation system that prevents spread of COVID-19 in indoor.
anteneh-gashawAnteneh Gashaw 06/03/2021 at 07:220 Comments
When one or multiple desks or tables with installed suction hose or pipe are not being used because no one is sitting in that spot, there is a valve that closes the pipe or hose opening. This will save power consumption and it will increase the suction capacity of the other tables because the closed pipes will be vacuumed.
