PCB Rev 2
A project log for Modernish-Wireless-Retro-Joystick
Wii Remote & ESP32 based wireless joystick interface for Atari-style joysticks to keep busy little hands away from vintage hardware.
mulcmumulcmu 06/09/2021 at 12:020 Comments
One leg of the digital pot needed to be tied to +5 and the other end floating.  Rev 1 of the PCB connected the leg to ground instead.  I was able to rework the current board to correct the but put a lot of heat into the chip getting the enamel wire soldered.  Doesn't seem like they are covering full range of resistance any more....
Also added a jumper to allow Atari to power the ESP32 dev board.  So far I've been powering with separate USB power supply.
Rev 2 PCB board order was placed last night.
