HITACHI HVAC Controler enclosure
10/30/2021 at 10:08 • 0 comments -
Final PCB
10/04/2021 at 15:03 • 3 commentsHere the final PCB & schematic. Very basic...
HomeAssistant setup
10/04/2021 at 14:58 • 0 commentsLet's go to HomeAssistant now.
First add this to configuration.yaml
climate: - platform: mqtt name: "Clim grand mur" unique_id: "clim_1" modes: - "off" - "heat" - "dry" - "cool" # - "auto" swing_modes: - "on" - "off" fan_modes: - "auto" - "high" - "medium" - "low" - "silent" power_command_topic: "device_7/cmnd/POWER" mode_command_topic: "device_7/cmnd/OPMODE" mode_state_topic: "device_7/STATE" mode_state_template: '{{ value_json.op_mode }}' temperature_command_topic: "device_7/cmnd/TEMP" temperature_state_topic: "device_7/STATE" temperature_state_template: '{{ value_json.temperature }}' fan_mode_command_topic: "device_7/cmnd/FAN" fan_mode_state_topic: "device_7/STATE" fan_mode_state_template: '{{ value_json.fan_speed }}' current_temperature_topic: "device_7/STATE" current_temperature_template: '{{ value_json.room_temp }}' swing_mode_command_topic: "device_7/cmnd/SWING" swing_mode_state_topic: "device_7/STATE" swing_mode_state_template: '{{ value_json.swing_mode }}' max_temp : 32 min_temp : 16 precision: 1.0 availability_topic: "device_7/LWT" payload_available: "Online" payload_not_available: "Offline"
and the card setup :
type: custom:thermostat-card entity: climate.clim_grand_mur title: Clim grand mur step: 1 no_card: false
Here the result :
HVAC OFF :
HVAC in COOL mode
HVAC mode list :
Zoom to the sketch
10/04/2021 at 14:40 • 0 commentsHere the main HVAC_status object that containts all properties (even those I not understood...)
struct HVAC_status { word power; //power (on, off) word op_mode; //mode (auto, hot, dry, cool, fan) word fan_speed; //fan speed (auto, high, medium, low, silent) word temperature; //temperature (16~32°C) word param_6; // ? word param_11; // ? word param_12; // ? word swing_mode; //swing mode (on, off) word room_temp; //room temperature word param_102; // ? word param_201; // ? // word param_300; // ? word param_301; // ? word param_302; // ? // word param_304; // ? // word param_800; // ? // word param_900; // ? } Hitachi_status;
Here the mode list and fan_list table.
const char mode_list[10][10] = { {"off"}, //0x0000 {"heat"}, //0x0010 {"dry"}, //0x0020 {"-"}, {"cool"}, //0x0040 {"fan_only"}, //0x0050 // {"auto"}, //0x8000 {"auto_heat"}, //0x8010 {"auto_dry"}, //0x8020 {"-"}, {"auto_cool"}, //0x8040 }; const char fan_list[5][7] = { {"auto"}, //0x00 {"high"}, //0x01 {"medium"}, //0x02 {"low"}, //0x03 {"silent"}, //0x04 };
I add 2 timers to trigger :
- HVAC write/scan : write to HVAC if neede or ask for status
- Send MQTT to HomeAssistant
/********************* Function management *****************/ if (millis()-scan_timer_counter > scan_timer) { scan_timer_counter = millis(); if(things_to_write){ // write to HVAC id request by callback set_HVAC(0x0800,0x07, false); // Enter setup mode set_HVAC(address_list[1], Hitachi_status.op_mode, true); // Op mode set_HVAC(0x0300,0x0000, true); // Unknow set_HVAC(address_list[3], Hitachi_status.temperature, true);// desired temp set_HVAC(address_list[1], Hitachi_status.op_mode, true); // Op mode set_HVAC(0x0300,0x0000, true); // Unknow set_HVAC(address_list[3], Hitachi_status.temperature, true);// desired temp set_HVAC(address_list[2], Hitachi_status.fan_speed, false); // fan speed set_HVAC(address_list[4], Hitachi_status.swing_mode, false);// swing mode set_HVAC(address_list[0], Hitachi_status.power, false); // power set_HVAC(0x0006,0x00, false); // Unknow set_HVAC(0x0007,0x00, false); // Unknow things_to_write = false; // done delay(500); // wait a while before send status request_HVAC_status(); // read status Send_fct(); // send status to HA } else { // read from HVAC en send if needed request_HVAC_status(); if (need_to_send_MQTT) Send_fct(); // send status to HA need_to_send_MQTT = false; } } /********************** Function send **********************/ if (millis()-send_timer_counter > send_timer) { send_timer_counter = millis(); Send_fct(); // send status to HA }
What next ....?
10/04/2021 at 14:17 • 0 commentsI choose finaly to communication with HomeAssistant via the MQTT integration.
MQTT is extremely light and reliable for this purpose.
I'll add also a custom thermostat-card. I'll show you this late...
Here me MQTT communication protocol :
I also add a frequently a STATE information in JSON format
device_7/STATE : {"power":"OFF","op_mode":"off","swing_mode":"off","fan_speed":"auto","temperature":21,"room_temp":22,"RSSI":-55}
and a MQTT last will message to be able to check if the device is on or offline.
device_7/LWT : Online
Back to work...
10/04/2021 at 13:58 • 0 commentsAfter a huge summer break, I'm back to finalize this project.
Next step is to write a simple sketch to be able to communicate with the HVAC. With a wemos D1 mini it's quite easy and with a telnet communication you can follow the communication remotely.
You need the SoftwareSerial library setup to :
HVACSerial.begin(9600, SWSERIAL_8O1, 13, 14, false); // baud raute: 9600, data size: 8 bits, parity: odd, stop bits: 1, RX:D7=13, TX:D5=14
I need some additionnal resistors to dop the serial input from 5V to 3.3V to be compliant with ESP8266.
Nice progress...
05/21/2021 at 09:40 • 0 commentsAfter many hours spend to snif the paquets here the first sharing. It was quite easy so far with the basic functions. I found 7 commands/informations out of 15. I add my investigation file
First we can find below the regular exchanged paquets every 6 sec. (Without any command)
Send by the SPX-WFG01 :
The A/C feedback
And now the command
So to here the list of adresses and content that I was able to catch.
There are still some question marks that have to be confirmed. And also 8 unkown information in the paquet. Maybe you have an idea ?
There are some functions that combined several of the command.
- The Leave Home function swith the A/C in heating mode, with 10°C and Low fan
- Auto operating mode switch Operating mode and fan mode to auto
In addition, all the timer functions are managed by the the remote control itself. So only the basic commands (On/Off) are send by the remote control as scheduled previously.According to the Hi-humo App description I should find also adresses releated to alarm functions. At this stage I'm not able to figure out how to trigger any alam from the A/C
First analysis
05/18/2021 at 17:39 • 0 commentsFirst thing first
Here the first analysis of the serial communication between the SPX-WFG01 and the A/C catch with 2 serial adaptators connected to my laptop.
The communication consist of ;
- A paquet sent by the gateway containing 15 lines starting with MT, where P is the adress.
- The response from the gateway containing 15 lines starting all with OK and where P is the containt at this adress.
in addition :
- - Carriage return is 0x0D 0x00
- - C is simply = P XOR 0xFF
Now start playing ...
I connect my smartphone to the Hi-humo app and try to catch some commands between
In this case a very diffrent paquet is sent to the A/C containing 12 lines staring all with ST, P contains the adress followed by the value.
Very first step
05/17/2021 at 14:43 • 0 commentsMy first step was to open the gateway and to check the pinout.
I can confirm the pinout posted by Florian (https://hackaday.io/project/168959-let-me-control-you-hitachi-air-conditioner)
Nevertheless the function of pin N°6 is still unclear for me. Let's check that later.
I mesured 5V for Rx & Tx echanges.
I'll come up soon with the first paquets...
