Startup
A project log for Internet of Grabby Things
An internet connected toy arcade grabbing machine. Created at a Raspberry Pi hackday in Leeds 2012.
chrisChris 11/05/2016 at 10:510 Comments
First create a init script for mjpg-streamer. create a file and use the script attached to the project page
sudo nano /etc/init.d/mjpg-streamer
or copy from a usb stick..
sudo cp -R /mnt/sda1/mjpg-streamer /etc/init.d
change permissions of the script
sudo chmod 0755 /etc/init.d/mjpg-streamer
to control the processes manually:
sudo /etc/init.d/webiopi <start | stop | force-reload | status >
sudo /etc/init.d/mjpg-streamer <start | stop >
or add scripts for start on boot
sudo update-rc.d webiopi defaults
sudo update-rc.d mjpg-streamer defaults
*note: there is currently a bug with webiopi that means you won't see the controls from boot. you need to force a reload.
sudo /etc/init.d/webiopi force-reload
to access the page using the default port go to
<ip address>:8000/index.html
