PCB design is done and working. The LEDs need custom code in the QMK firmware. The standard firmware has 1 set of LEDs, but I designed the PCB with a single strip of LEDs for both under glow and key LEDs. Except for the LEDs not being easily programmed, the keyboard works. I just don't have the bandwidth right now to continue this project. Anyone interested in design files or software can contact me.
I should point out the dual USB-C ports are to match the original K-type, however you can only use 1 of them at a time. The keyboard is not a USB hub and the ports are essentially wired in parallel. It allows you to use the port on the same side as your PC, but not attach your mouse or secondary keyboard to the second port.
Brian Barrett
Thuan Le
TEC.IST
Mukesh Sankhla
