Second PCB revision finished
A project log for B-Type Keyboard PCB
K-Type Keyboard replacement PCB. Uses TMK/QMK Firmware
brian-barrettBrian Barrett 05/18/2021 at 03:310 Comments
First revision of the PCB was missing a trace. You can see it in the main project image. This has been fixed and I've assembled and tested the current version of the PCB. It's working fully, with the exception that the firmware does not properly animate the LEDs. This could be fixed in software, but I don't have the time or inclination at the moment.
