V1.0 Terminal Functionality
A project log for DL1416SmarTerm LED Computer/Terminal
Old and new come together for an old school intelligent terminal.
dan-julioDan Julio 11/06/2016 at 04:380 Comments
I started the project without any clearly defined goals for the terminal functionality other than it had to scroll. I wanted a terminal to connect to a nebulously defined future computer project but was stuck with testing with modern computer...which still speak to command line environments with ANSI escape sequences. Why not emulate the classic computer terminal progenitors then? I started with the VT100 but soon found I liked the additional features that DEC added with the VT102 such as the ability to support printers and more efficient editing capabilities. This meant a lot of escape sequence decoding. I ended up wading through a lot of websites describing various ANSI escape sequences but finally found http://vt100.net as the best source. Obviously I couldn't deal with commands to change the font or font-size so I ignored those but I tried to deal with everything else and I added a couple of escape sequences from more advanced terminals that supported some function (like cursor blink) that my display could also support. I tested my code using both a Raspberry Pi running Raspian and my Mac OS X laptop. Interestingly the OS X system wanted a much more modern set of ANSI escape sequences even when I thought I told it to limit to the old VT102 set. I ended up adding code to ignore entire classes of escape sequences such as "Operating System" types. My main test was bash shell interactivity and the vi text editor. I used a diagnostic mode in my code to dump the incoming stream to the USB serial port so I could see what the terminal had seen when the display didn't match what I expected (which, at least at first, was a lot). It was entertaining if nothing else. A lot of modern code thinks nothing of sending the same escape sequence multiple times in a row.
Ultimately for my first go-around I ended up with the following control character and escape sequence "command set" for the terminal. I made the conscious decision not to support all the control characters in the same way DEC terminals did to match some more "stupid" terminals that I had run across over the years.
Control Characters Implemented
     CTRL-C                           EOT - Break command for Tiny Basic (ignored in Terminal mode)
     CTRL-G                           BELL - sends BELL to keyboard (rings keyboard bell)
     CTRL-H                           BS - backspace cursor
     CTRL-I                           TAB - forwardspace cursor to next tab position (default values: 1, 2, 4
                                            or 8 positions, configurable)
     CTRL-J                           LF - Linefeed character (moves cursor down one row; may also
                                           be configured to include a CR)
     CTRL-K                           VT - Vertical tab (moves cursor up one position) (**)
     CTRL-L                           FF - Formfeed (clear screen) (**)
     CTRL-M                           CR - Carriage return (moves cursor to start of line; may also
                                           be configured to include a LF)
     ESC (*)                          Escape - starts escape sequence
     DEL                              Delete - backspace cursor, deleting character first (**)
     Notes:
      *  The EOT key on the keyboard is treated as an Escape in terminal mode and a CTRL-C
         (break) in Tiny Basic mode.
      ** These control characters are not VT100/ANSI compliant.  They exist for compatibility with
         other, more primitive, terminals.
ANSI Sequences Implemented (numeric arguments in decimal ASCII notation are contained with <>)
     ESC[;H                           Cursor Position
     ESC[;f                           Horizontal and Vertical Position (same as Cursor Position)
     ESC[A                            Cursor Up
     ESC[B                            Cursor Down
     ESC[C                            Cursor Forward
     ESC[D                            Cursor Backward
     ESC[s                            Save Cursor Position
     ESC[u                            Restore Cursor Position
     ESC7                             Save Cursor Position, origin mode and cursor attributes (*)
     ESC8                             Restore Cursor Position, origin mode and cursor attributes (*)
     ESC[J                            Erase Down
     ESC[1J                           Erase Up
     ESC[2J                           Erase Display
     ESC[K                            Erase End of Line
     ESC[1K                           Erase Start of Line
     ESC[2K                           Erase Line
     ESC[L                            Insert Line
     ESC[M                            Delete Line
     ESC[P                            Delete Character
     ESC[c / ESC[0c / ESCZ            Query Device Attributes (responds with VT102 ESC[?6c)
     ESC[5n                           Query Device Status (responds with Report Read, no malfunctions ESC[0n)
     ESC[6n                           Query Cursor Position (responds with Report Cursor Position ESC[;R)
     ESC[?15n                         Query Printer Status (responds with
                                        ESC[?13n if printer is offline
                                        ESC[?11n if printer is out of paper
                                        ESC[?10n if printer is ready to print
     ESCc                             Reset Device
     ESCD                             Scroll Down One Line
     ESCE                             Next Line
     ESCM                             Scroll Up One Line
     ESCH                             Set Tab
     ESC[0g / ESC[g                   Clear Tab at position
     ESC[3g                           Clear all tabs
     ESC[;r                           Set scrolling region
     ESC[r                            Reset scrolling region
     ESC[4h                           Enable Character Insertion
     ESC[4l                           Disable Character Insertion
     ESC[7h                           Enable Line Wrap
     ESC[7l                           Disable Line Wrap
     ESC[12h                          Disable Local Echo
     ESC[12l                          Enable Local Echo
     ESC[20h                          Set New Line Mode (new line also includes CR, CR sends CR+LF)
     ESC[20l                          Reset New Line Mode
     ESC[?6h                          Set Origin Mode
     ESC[?6l                          Reset Origin Mode
     ESC[?25h                         Make Cursor visible
     ESC[?25l                         Make Cursor invisible
     ESC[0q / ESC[1q                  Cursor Blink (**)
     ESC[2q                           Cursor Solid (**)
     ESC[i / ESC[0i                   Print Screen or scrolling region (based on Printer Extend Mode)
     ESC[?1i                          Print Line with cursor (followed by CR/LF)
     ESC[4i                           Disable Print log
     ESC[5i                           Start Print log (send incoming data to printer instead of screen)
     ESC[?4i                          Turn off Auto Print
     ESC[?5i                          Turn on Auto Print (print line after cursor moved off line w/ LF, FF, VT)
     ESC[?18h                         Set FF as print screen terminator
     ESC[?18l                         Set nothing as print screen terminator
     ESC[?19h                         Set full screen to print during print screen
     ESC[?19l                         Set scrolling region to print during print screen
     ESC#                             Line Attributes (IGNORED)
     ESC(                             Select Character Set (IGNORED)
     ESC)                             Select Character Set (IGNORED)
     ESC];BEL                         Operating System Command (IGNORED)
   Notes:
    *  This isn't ANSI compliant, instead of storing character attribute, we are storing cursor attributes
    ** These are VT520 commands
