Hackaday.io Hackaday.io
Sign up Log in
µ-Sonum
A VST to experiment with granular synthesis
matteo-amerenaMatteo Amerena
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
69
0
0
0
Team (1)
  • matteo-amerenaMatteo Amerena
Join this project's team
  • Github
completed project
This project was created on 05/18/2021 and last updated 4 years ago.
Description
The application is built in C++ using the JUCE framework and an Hilbert transform implementation. The goal is to provide a useful and relatively simple tool to play with granular synthesis and understand it better, along with easily experiencing independent time-stretching and frequency shifting.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A tool made in 15 minutes that will help you cut perfect V-Groove in polystyrene foam. The groove will help bend the foam.
Project Owner Contributor
Cheap-dirty-perfect V-Groove Foam Cutter / Bender
ftreganftregan
From 28-st of January 2016 till 8-th of February 2016 anyone can try SelfieBot.
Endurance SelfieBot demo starts! Hurry up!!!
georgefomitchefgeorgefomitchef
Ohh is it the time to buy raincoats and Umbrella? Check it using this hack
Will it rain?
ayushAyush
what if it was possible to create objects in a different way - freely in space, without contact, using a tiny amount of matter nad energy...
Free creation of objects
michaMichał
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "µ-Sonum", please tell us the reason.
Send message
Remove Member
