the gear in detail....
A project log for cost efficient robot actuator
creating a root actuator based for high cost efficient components for high torque applications
Y.clubY.club 05/18/2021 at 18:110 Comments
So how do we actually combine the gear with the motor?
Following flange should to the job....
On the 8308 looks like this.... same connection as to 8318 ... I will explain later why i switched for a smaller motor....
If we now combine this with the gear kit from @Josh Pieper we get following:
