Main rotary axis bearing changed
A project log for PnPAssist
PnPAssist is a tool that helps you to assemble PCB boards manually.
Nuri ErginerNuri Erginer 07/26/2021 at 17:170 Comments
I have change the main rotary axis bearing to
16010 bearing 50x80x10
The old one is not precise enough under microscope.
The BOM updated
