Controller Board Schematics
A project log for PnPAssist
PnPAssist is a tool that helps you to assemble PCB boards manually.
Nuri ErginerNuri Erginer 10/18/2021 at 07:430 Comments
The PnPAssist Controller Board is same for V1 and V2. You can find all the eagle source files here: https://github.com/makerstorage/pnpAssist/tree/main/Controller/hardware
I also added the pdf schematics below:
https://cdn.hackaday.io/files/1798787695900352/main_board.pdf
