Low-cost BLE KT6368A--Only USD 0.5 per chip
KT6368A is a dual-mode Bluetooth Transparent Transmission module that supports Bluetooth 5.1 version BLE and 2.1 version SPP function.
Public Chat
KT6368A is a dual-mode pure data chip that supports Bluetooth 5.1 version BLE and 2.1 version SPP function. The highlight of the chip is its ultra-small size and ultra-low price. And simple transparent transmission and serial AT control function. Greatly reduce the difficulty and cost of developing embedded Bluetooth in other products. KT6368A supports connecting to mobile phones for two-way data interaction, commonly known as "Bluetooth Transparent Transmission". Through the UART interface, it supports common AT commands, such as: setting name, setting address, setting baud rate and so on.
KT6368A transparent transmission test v1.0.pdf
KT6368A transparent transmission test steps
Adobe Portable Document Format - 242.41 kB - 05/27/2021 at 03:20
Preview
Download
x-zip-compressed - 118.38 kB - 05/27/2021 at 01:37
Download
KT6368A Datasheet V1.0.pdf
KT6368A Datasheet
Adobe Portable Document Format - 511.98 kB - 05/27/2021 at 01:28
Preview
Download
KT6368A AT Command en v1.0.pdf
KT6368A AT Command
Adobe Portable Document Format - 214.80 kB - 05/22/2021 at 05:07
Preview
Download
Kai Wu wrote 09/28/2023 at 22:59 point
Q: can this chip transmit bluetooth audio signal to be received directly by a bluetooth earphones?
Ken Yap wrote 05/26/2021 at 03:23 point
Is there a data sheet for the chip somewhere? A search didn't find it.
IOTMCU wrote 05/27/2021 at 01:40 point
Hi,
Please see the FILES, has updated.
Ken Yap wrote 05/27/2021 at 01:45 point
👍 Thanks.
