PCB_Gerber_ESP32_Relay_8channel_01.zipPCB Gerber file for this projectZip Archive - 149.19 kB - 05/22/2021 at 10:21 |
Code_IR_Button_HEX_Code.zipCode to get the HEX codeZip Archive - 619.00 bytes - 05/22/2021 at 10:20 |
Code_ESP32_IR_Blynk_WiFi_Manual_Buttons_8Relays.zipCode for this ESP32 Blynk home automation system with button (momentary)Zip Archive - 2.64 kB - 05/22/2021 at 10:20 |
Code_ESP32_IR_Blynk_WiFi_Manual_Switches_8Relays.zipCode for this ESP32 Blynk home automation system with switch (latched)Zip Archive - 3.24 kB - 05/22/2021 at 10:19 |
