PCB_Gerber_ESP32_Relay_8channel_01.zipPCB Gerber for this projectZip Archive - 149.19 kB - 05/22/2021 at 11:09 |
Code_IR_Button_HEX_Code.zipCode to get the HEX codes from remoteZip Archive - 619.00 bytes - 05/22/2021 at 11:08 |
Code_ESP32_Alexa_IR_Manual_Button_8Relays.zipCode for ESP32 Alexa home automation with push buttons (momentary)Zip Archive - 3.38 kB - 05/22/2021 at 11:08 |
Code_ESP32_Alexa_IR_Manual_Switch_8Relays.zipCode for ESP32 Alexa home automation with switch (latched)Zip Archive - 3.33 kB - 05/22/2021 at 11:05 |
