Getting the Display to Work
A project log for CRYPTOiNK
Uses an E-ink Display to Realtime Update Select Crypto Currencys
john-loefflerJohn Loeffler 05/27/2021 at 14:110 Comments
Goals:
1) A Low Powered E-Paper Display
2) Graphically Display Cryptocurrency Data
3) Attach to a Refrigerator or Door (Magnets and Suction Cups)
4) Update on a 10min Basis
5) Visible 6-12Ft
//----------------------Extended Goals----------------------
5) Encoder wheel + OLED to input SSID and Passoword
6) Buttons that, when pressed, go into details of each Cryptocurrency
//-----------------Estimated BOM-------------------
The Standard hardware for this Project are:
1)  1x     Waveshare Esp8266 E paper Driver
2) 1x     Waveshare 7.5" B/W/R E paper (640x384)
3) 7x     12mm Tactile Buttons
4) 1x      Encoder (For Wifi Setup)
5) 1x     OLED Display (For Wifi Setup)
I Started out using the GxEPD2 Library to create the format
I Used Kevin Darrah's E-paper Tutorial on how to crate graphics for the E-Paper Display using the tool Image 2 LCD (https://cdn.hackaday.io/files/1799517699023584/Image2Lcd.zip)
Using this Tutorial I was able to produce a format that can be seen from 6-12ft Away
