WinDIY_2 - Horizontal Axis Wind Turbine
A new version of the mostly 3D printed windturbine incl. a new version of a 3D printed generator.
FabFab
Based on my experiences of the first version of WinDIY (https://hackaday.io/project/172328-windiy-hawt-wind-turbine) I'm aiming to build a new, simpler and more powerfull design.
The final goal is (again) to develop a wind turbine that generates energy from wind power and adapts as autonomously as possible to the current wind conditions.
More information on all these topics in the log. :)
Last year I presented a wind turbine called "WinDIY", which can be largely made from 3D printable parts. (You can find information on this here: https://nerdiy.de/en/windiy-die-wind-turbine-aus-dem-3d-drucker/ and here: https://hackaday.io/project/172328-windiy-hawt-wind-turbine)
Relatively quickly after building the first prototype, it became clear that I would build a new version. The construction of the first WinDIY version worked in principle, but there was a need for optimization in some areas.
I now want to implement these optimizations with a completely new design. For this, not only the design of the blades is being revised. The 3D printed generator will also be completely redesigned. In addition, I plan to simplify part of the somewhat complex mechanics. Ultimately, the structure should be lighter, the turbine should run more efficiently and also be a little more compact.
I'm currently working on the first basics such as the newly designed pitch actuator and the generator. You can see some of the first progress in the project logs. :)
Support:
If you want to support me, you can do so by like on this project page, on Instagram or by donating a coffee. :)
Licenses:
Content that is not based on software/code: Unless otherwise stated, all works presented here that are not based on software/code are subject to the CC BY-NC-SA 4.0 license (attribution – non-commercial – dissemination under the same conditions 4.0 international).
You can find a summary here: https://creativecommons.org/licenses/by-nc-sa/4.0/deed.de
You can find the complete legal text here: https://creativecommons.org/licenses/by-nc-sa/4.0/legalcode.de
Software/code-based works Unless otherwise stated, all software/code-based works presented here are subject to the GNU Affero General Public License v3.0
You can find a summary here: https://tldrlegal.com/license/gnu-affero-general-public-license-v3-(agpl-3.0)#summary
The complete legal text can be found here: https://www.gnu.org/licenses/agpl-3.0.de.html
  • Modular Anemometer for WinDIY_2 (and other projects)
    Fab06/09/2021 at 14:47 0 comments
    In the last few days I have been working on the first drafts for the anemometer for WinDIY_2. You can find the first information about this in the following project log: https://hackaday.io/project/180202-anemosens-sla-printed-anemometer
    Since I've always wanted to build an anemometer anyway to be able to collect wind data for my weather station, I built the sensor modular so that it can also be used in other situations (e.g. a weather station).
    I tried to make the wind sensor as compact as possible. The sensor electronics will be built into the 27mm thick shaft. Later I want to build an adapter board so that the wind data can then also be read via RS485 or USB. :)
  • First assembly tests on the stator
    Fab05/26/2021 at 16:19 0 comments
    The last few days I also started the first assembly of the stator.
    Actually, this was already the second version of the stator. For the first version, I had planned to insert the windings from behind into recesses in the stator. However, they could not be attached well that way. In addition, the heat dissipation would have been very poor because the coils were almost completely surrounded by the stator housing.
    The new stator is constructed in such a way that the coils are placed in recesses from the outside and screwed together with two M3 screws. This makes the construction and the fastening even easier and the ventilation better. Additionaly this reduces the air gap between the coils and the magnets by approx. 2mm.
    You can see more information, pictures and a video of the installation of a coil insert in the following section.
    View of the first stator version (top), the second stator version (bottom) and the stator (white).
    Rotor including inserted stator (first version)
    Gap between magnets and coils on the first stator version
    Gap between magnets and coils on the second stator version
    Stator including assembled winding insert
    Prepared winding inserts
  • Load test of the pitch actuator aka worm gear
    Fab05/26/2021 at 16:18 0 comments
    Possibly you remember the last construction of the pitch actuator for the first version of #WinDIY.
    (If not you can see it for example here: https://hackaday.io/project/172328-windiy-hawt-wind-turbine/log/181897-pitchaktor-mark2-mark3-and-mark4)
    At that time I built four versions because after each version I thought that I had now found the perfect design (which of course I didn't have).
    That's why I want to test the new design more this time before using it in the final design. For this purpose I built a small test setup with which I can test the torque of the pitch actuator. I printed a wheel with a radius of 10cm and attached a rope to it. In order to determine the maximum torque I have attached various weights and determined at which weight the gearbox is blocked. The torque can then be calculated using the weight force of the attached weight.
    Result: The pitch actuator is strong enough for my application. But of course every gear also has a final boss. ⁣:)
    The heaviest wheight was about 3kg. At that point I did also end the test since this should be already more than sufficient. :)
    You can see the a summary of the test in the following video
  • New pitch actuator
    Fab05/26/2021 at 16:14 0 comments
    In the first version of WinDIY I installed a pitch actuator. With this it was possible to adjust the angle of attack of the wings.
    Unfortunately, the build was very complex and large. (You can find more information here: https://hackaday.io/project/172328/log/181897-pitchaktor-mark2-mark3-and-mark4 )
    So I want to use a different system for the new version. I'm currently working on a 3d printed worm gear. Three of these should then be installed in the hub of the turbine in order to adjust the blades directly.
    You can see the working prototype in the video below. This construction has several advantages:
    • the wing can be adjusted much faster
    • the mechanism is self-locking
    • the mechanic has much less play
    • easier to set up
    Here is the promised video and a few pictures. :)
View all 4 project logs
