First test of the blade mount system
A project log for WinDIY_2 - Horizontal Axis Wind Turbine
A new version of the mostly 3D printed windturbine incl. a new version of a 3D printed generator.
FabFab 10/27/2021 at 17:300 Comments
As with the first version of WinDIY, I want to connect the blades to the hub with this version in such a way that it can be easily exchanged if the worst comes to the worst. For this purpose I designed a simple hexagonal plug-in device, which is a bit tight but works in principle. :)
