things
A project log for NSCE-ngbrain
scalable hardware for neural network system
3drobert3drobert 08/30/2021 at 21:440 Comments
basic tester
_______________________________________________________________________
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Playing with graffite to get a potenciometer I found one form to maintain graffite on paper, even in plastic.
Adding Iodine ensure the hardeness of this
At the left without Iodine and rubbed and at the right with Iodine and rubbed too
with and without
you can see iodine on the edges
Maybe It can be used for 3d printings or air bearings
09/02/2021
09/04/2021
NAND gates by using AC phases with no active elements?
Teorically delay by active components would not exist (combinational).
The half adder is the next to try :D
not NAND at this but I will continue trying
09/06/2021
I'm going to make two instrumentation amplifiers with OPAMPs to have differential probes to get the diode curves that also can be usefully to be able do some test over my custom compounds and know if I have some something interesting :)
09/07/2021
TL084 as instrumentation amplifier and voltage reference
09/08/2021
Better results with symetrical source. Even with capacitors I have something like a diode curve. I have put a little more impedance to test this function generator but also I get nice sensibility without them for other purposes
forward diode
reverse diode
conductor
insulator
capacitor
inductor
