fixed up communications
A project log for NSCE-ngbrain
scalable hardware for neural network system
3drobert3drobert 11/14/2021 at 11:420 Comments
2 slaves sending data. Clocks OK. Heat OK. Transmission dont stop now. ::smile::
I will accelerate transmission because I had to slow it down to check the problems.
Finally I can continue preparing the Plot class and make more advances with the reinforcement learning class (ConvnetJS based) and see what problems may be there
