Modifying the screen to work with 5 Volts
A project log for Raspberry Pi 3 Gameboy
This is a DIY Raspberry Pi 3 gaming handheld running RetroPie to play all your classics!
sotasystemssotasystems 11/07/2016 at 20:090 Comments
The screen won't work with 5 Volts out of the box, so it needs to be modified a litlle.
For that I soldered a wire to the power line and the 2nd pin of the power regulator IC and that does the trick:
I then soldered on wires to test it out to the corresponding pins:
And it works!
