Adding a safe shutdown switch
A project log for Raspberry Pi 3 Gameboy
This is a DIY Raspberry Pi 3 gaming handheld running RetroPie to play all your classics!
sotasystemssotasystems 11/07/2016 at 21:400 Comments
Next up is to add a tactile switch in the upper right to make the pi safely shutdown when this switch is held for 1 second.
the switch is closing GND to GPIO pin 37.
