Over-the-Air (OTA) Firmware Upgrade through MQTT
A project log for QingStation, Ultrasonic Anemometer/Weather Station
An opensource compact ultrasonic anemometer/weather station
jianjia-maJianjia Ma 07/13/2021 at 10:310 Comments
Over the air firmware upgrading give QingStation a huge flexibility in a unmanned field application, For example, when the QingStation is installed on the roof of a building, it is really annoying to dismount everything and just to download an upgraded firmware.
Supporting OTA means we can just sit in front of the PC and upgrade the firmware remotely, what a huge improvement!
Methods
Since we already support MQTT to publish the weather data, we can make a minor modification to the existing MQTT to transfer firmware.
On the PC side, a python script will perform the firmware segmenting and packaging. The MQTT client used here is Paho-MQTT.
The script will split the the firmware to a size of 256 byte package. An package ID and checksum will be added and put into MQTT message payload.
After every data package is sent, the script wait for an Ack package sent from QingStation. If validation is correct, it will send the next package, if not, it will resend the last one.
Message
This is the messages protocol that exchanges between QingStation and the python script. You can see that it is very simplified.
All of them are to simplify the implementation.
Flash Space Allocation
The MCU we used STM32L476RG has 2 independent flash banks that can be read or written at the same time. The main applications is running on the bank 1, so we just use bank 2 to store the OTA firmware. (No need to store in SD card) After the transmission is finished, we can then use our bootloader to copy the OTA firmware to bank 1.
Here is the memory allocation for the current setup.
Firmware TAG
In the above diagram, you might notice there are some sections call xxx tag. That is where the description of the firmware. It is stored in a readable string format separated by comma. The most important parts are:
Finishing the update
Once all the firmware is transferred completed, the application destroys its own tag to mark the firmware invalid. Then it makes a software reset and handover to the bootloader.
The bootloader will read the tags especially the MD5 checksum. It will perform a MD5 checksum through the Application and OTA space, and it will compare the MD5 with those tags.
Once the bootloader checks and finds out that application space is invalid and OTA is valid, it will copy the firmware from OTA space to Application space. Or when both firmware are good and but OTA version > application version, it will also perform an update. (copy OTA to application).
Performance
I did a test with the below setting: When using ESP8266 as the WIFI module and the broker from AWS located in the UK.
Not great but still faster than go to the roof and disassembling everything.
PS: the bootloader also supports update from SD card. See dedicated document for detail (not ready).
