Thought it might be a useful idea to have hardware handshake enabled.
In the top file CPU entity:
-- TTY1 Interfaces tty1BR => uartBR9600, --! TTY1 is 9600 Baud tty1HS => uartHShw, --! TTY1 uses hardware handshake tty1CTS => TTY1_CTS, --! TTY1 CTS (in) tty1RTS => TTY1_RTS, --! TTY1 RTS (out) tty1RXD => TTY1_RXD, --! TTY1 RXD (to RS-232 interface) tty1TXD => TTY1_TXD, --! TTY1 TXD (to RS-232 interface)
From Doug Jones PDP-8 page. "From the beginning, PDP-8 software has generally assumed that textual I/O would be in 7 bit ASCII. Most early PDP-8 systems used teletypes as console terminals; as sold by DEC, these were configured for mark parity, so most older software assumes 7 bit ASCII, upper case only, with the 8th bit set to 1. "
In PuTTY:
Works!
