Running OS/8
A project log for OpenCores PDP-8 on FPGA
land-boardscomland-boards.com 05/30/2021 at 18:130 Comments
Fresh Boot
Reboot
The Internal SRAM needs to reloaded.
Alternate Re-boot
From the OS8 Handbook. Boots to command line.
Files on the RK08 (SD Card)
ABSLDR.SV   6            FLOP2 .BI   2            RALF  .SV  19
ADVENT.DC   9            FORLIB.RL 170            REMEM .SV   5
ADVENT.FT  11            FOTP  .SV   8            RESORC.SV  14
ADVENT.IN   1            FRTS  .SV  26            RKBOOT.SV   2
ADVENT.LD 145            FUGUE .MU  42            RKCOPY.SV  11
ADVENT.RL   4            FUTIL .SV  27            RKFRMT.SV   9
ADVENT.TX 201            F4    .SV  20            RKUTIL.SV  15
AINDX .DA  50            GETIN .FT   6            RLFRMT.SV   7
AMAIN .RA 270            GETIN .RL   4            RL2FMT.SV   8
AMAIN .RL  50            GETWRD.RA  16            RND   .FT   1
ATEXT .DA 144            GETWRD.RL   2            RND   .RL   2
A5TOA1.RA   6            HEADER.SV  14            RSPEAK.RA   3
A5TOA1.RL   3            HELP  .HL 102            RSPEAK.RL   2
BASIC .AF   4            HELP  .SV   8            RSTRGM.FT  13
BASIC .BA  11            INIT  .TX   1            RSTRGM.RL   8
BASIC .FF   4            INITAD.FT  65            RTFLOP.SV  15
BASIC .OV  16            INITAD.RL  23            RUNAD .BI   1
BASIC .SF   4            INUSE .TE   8            RXCOPY.SV   9
BASIC .SV  11            IO    .FT   2            RXFIX .SV   3
BASIC .UF   2            IO    .RL   2            RXREAD.SV   7
BASIC .WS   1            JUGGLE.RA   3            SAVEGM.FT  13
BATCH .SV  10            JUGGLE.RL   2            SAVEGM.RL   8
BCOMP .SV  17            KL8E  .PA  53            SD    .BN   1
BITMAP.SV   5            K12DEB.SV   4            SD    .LS  28
BITSET.RA  11            K12DEC.SV   5            SD    .PA  11
BITSET.RL   3            K12DJG.SV  33            SEED  .RA   7
BLOAD .SV   8            K12ENB.SV   4            SEED  .RL   2
BLOCKS.SV   8            K12ENC.SV   6            SET   .SV  20
BOOK  .BI   1            K12MIT.SV  33            SPACWR.BA  39
BOOT  .SV   5            LAYOUT.TX   4            SPEAK .RA  28
BRTS  .SV  15            LCSYS .BI   3            SPEAK .RL   4
BUG   .FT   3            LOAD  .BI   1            SRCCOM.SV   5
BUG   .RL   2            LOAD  .LS   8            SVDUMP.SV   4
BUILD .SV  37            LOAD  .SV  16            TDCOPY.SV   7
CAMP  .SV  13            LPTSPL.SV  10            TDFRMT.SV   9
CARRY .RA   5            MCPIP .SV  13            TECKBM.TE   2
CARRY .RL   2            MOVE  .RA   4            TECO  .IN   1
CCL   .SV  31            MOVE  .RL   2            TECO  .SV  32
CHESS .SV  15            MSBAT .SV  23            TECO  .TE   1
COMPAF.SV   5            MUSIC .SV   9            UCSYS .BI   3
COMPIL.BI   2            PAL8  .SV  19            USR   .RA  46
CONVRT.SV   5            PARAM .SV  12            USR   .RL   4
CREF  .SV  13            PASS2 .SV  20            VOCAB .RA   7
DECX8 .SV  43            PASS2O.SV   5            VOCAB .RL   3
DIRECT.SV   7            PASS3 .SV   8            VTEDIT.TE   8
DOUGTE.ST   1            PCT   .RA   2            WILD  .BI   1
DROP  .RA   4            PCT   .RL   2            WILD  .DI   5
DROP  .RL   2            PIP   .SV  11            WILD  .TE   2
DSTROY.RA   1            PIP10 .SV  17            WILD  .TM   1
DSTROY.RL   2            PSPEAK.RA   5            WPFLOP.SV  14
DTCOPY.SV   5            PSPEAK.RL   2            YES   .FT   2
DTFRMT.SV   7            PUT   .RA   3            YES   .RL   3
EDIT  .SV  10            PUT   .RL   2            2000  .TX   1
EPIC  .SV  14            QUIT  .SV   2            31    .76   1
FLOP  .HN   3
 Resources
.R RESORC
*/E
163 FILES IN 2639 BLOCKS USING 5 SEGMENTS
553 FREE BLOCKS (7 EMPTIES)
#  NAME TYPE MODE SIZ BLK KIND U V ENT USER
01 SYS  RK8E RWF 3248 SYS      0 F  07
02 DSK  RK8E RWF 3248 SYS      0 F  07
03 BAT  BAT  R        16         B  00
04 TTY  TTY  RW       17+ KL8E   E 176
05 RKA0 RK8E RWF 3248 20  RK05 0 A  20
06 RKB0 RK8E RWF 3248 20  RK05 0 A  21
07 RKA1 RK8E RWF 3248 20  RK05 1 A  22
10 RKB1 RK8E RWF 3248 20  RK05 1 A  23
11 RKA2 RK8E RWF 3248 20  RK05 2 A  24
12 RKB2 RK8E RWF 3248 20  RK05 2 A  25
13 RXA0 RX02 RWF  988 21+           32
14 RXA1 RX02 RWF  988 21+           36
15 B3    37  RWF      22+          117
16 B4    37  RWF      22+          113
FREE DEVICE SLOTS: 01,  FREE BLOCK SLOTS: 03
OS/8 V3T
