Last correction
A project log for Magic-1 computer on Logisim
Simulate Bill Buzbee's Magic-1 computer with Logisim Evolution
Jacques PelletierJacques Pelletier 07/10/2021 at 09:080 Comments
I inverted the latch outputs entering U47 in Faults & Interrupts.
This corrected a bug where the CPU was doing an NP fault right after reset.
With this, the fibonaci test seems to run fine (no way to check).
This will be the last modif for a while unless someone finds a bug.
All the code is on github on the link provided.
Time to go on other projects!
