DIY EBike Battery System
Use common power tool batteries to power your ebike!
In an effort to save costs for EBike batteries, we created a battery system that utilizes 40V RYOBI power tool batteries to power an EBike. We used a combination of 3D printed and COTS parts to make the mounts and wiring harnesses. Our system involves two batteries, connected to the motor in parallel via a Y-harness. Each battery is mounted to the bike on the mounts we designed, and an internal wire harness routes power to the Y-harness.
Check out our video here: https://youtu.be/FgjxSFlo72g
And our files and written documentation here: https://github.com/pittxprojects/ebike
Student contributors include Maya Román, Jack Rozzo, Peter DeNicola, and Nick Bohn.
f3z - 1.57 MB - 05/30/2021 at 20:02
Download
f3z - 5.88 MB - 05/30/2021 at 20:02
Download
f3z - 6.17 MB - 05/30/2021 at 20:02
Download
f3d - 2.96 MB - 05/30/2021 at 20:02
Download
f3z - 1.28 MB - 05/30/2021 at 20:02
Download
View all 11 files
Charlie Lindahl wrote 06/07/2021 at 16:25 point
Where's the BOM? Specifically, the motor?
The GITHUB documentation MENTIONS the BOM, but does not provide it. I'm interested in finding out how to obtain the motor, and then I can either try to install myself or, as the notes suggest, go to a bike shop to help in the installation.
I can do the 3D printing of the battery mounts and also the wiring.
Assuming I can get the project working I could add power monitoring/logging to measure performance and maybe crowdsource results with other makers.
Charlie in Houston, TX
Charlie Lindahl wrote 06/07/2021 at 16:39 point
SOME answers to my own question (google search on "mid-drive bike motors" :
BAFANG Electric Bicycle Conversion Kit ($899)
https://www.amazon.com/Bafang-Lastest-Electric-Bicycle-Conversion/dp/B01FX7GL1Q
And
Luna Cycles Kits
https://lunacycle.com/mid-drive-kits/
Charlie Lindahl wrote 06/07/2021 at 16:45 point
BEST answer so far, article at ELECTRICBIKE.COM
26 Mid Drive Kits for DIY Electric Bikes
https://www.electricbike.com/mid-drive-kits/
Scott wrote 06/07/2021 at 12:20 point
Looks like an awesome project! Out of curiosity, what is the max speed the bike can reach and for how long? Keep up the great work!
adam.klotblixt wrote 06/01/2021 at 04:48 point
A very nice project. I just wish batteries here in Sweden were cheap enough to utilize this way. Had a look online and 2 of those batteries would cost roughly 3600sek which is in the same region as a cheap e-bike battery of >10Ah.
What happens when 2 batteries are inserted if they have uneven charge/voltage? Does the internal BMS:es even the voltages out safely, or is there an unsafe "fast charge" of the battery with lower voltage?
