Winding Down
A project log for Exploring Flip Dots
I have this idea for a slow but relatively cheap flip dot display that I want to try out. This is definitely a research project.
Michael GardiMichael Gardi 08/30/2021 at 16:470 Comments
I haven't made much progress on this project probably because I don't have a pressing need right now for a large cheap slow flip dot display. Mostly I was just noodling with ideas.  So I'm going to close this project for now.
If you are interested in pursuing this idea further you should check out :
      https://hackaday.com/2021/06/24/mechanically-multiplexed-flip-dot/
Not only did James Bruton come up with the perfect name (Mechanically Multiplexed Flip- Dots) for the concept that I have been trying to explore hare, he has produced a much more fully realized demonstration of how it would work with his 5 x 3 ping pong ball display.
