A 3D Printed Mechanical Seven Segment Display.
A 3D Printed Mechanical Seven Segment Display: Design and Test.
Public Chat
Video of CAD model and 3D printed segment "A" test is here: https://youtu.be/hUMeViZBy24.
bawivat972 wrote 02/26/2024 at 10:32 point
We’ll also provide Sheetz Hot Beverages Menu With Prices for each beverage, So you can budget accordingly. https://sheetz-menu.info/sheetz-hot-beverages-menu/
Dan Maloney wrote 06/03/2021 at 21:56 point
Hey Greg, pretty cool. Just curious -- have you played with making the display light-emitting? IOW, each segment could be printed in black and act as a shutter to block light coming from inside the display. You might have to include some kind of diffuser behind the segment windows, but that could look really sharp.
Not that it doesn't already look sharp, just a thought.
Greg Zumwalt wrote 06/05/2021 at 13:50 point
Hi Dan!
Thank you very much, I'm glad you enjoyed it!
I had not thought of lighting the segments, but it should not be too difficult to add a diffuser to the bezel and change the segment colors to black.
Thanks again!
Greg
