This L298N Motor Driver Module is a high-power motor driver module for operating DC Motors and Stepper Motors. This consists of an L298N IC and a 78M05 5V regulator. This module can control up to 4 DC motors, or 2 DC motors with directional and speed control.
L298 Driver Module Features & Specifications:
  • Driver Model: L298N 2A
  • Driver Chip: Double H Bridge L298N
  • Motor Supply Voltage (Maximum): 46V
  • Motor Supply Current (Maximum): 2A
  • Logic Voltage: 5V
  • Driver Voltage: 5-35V
  • Driver Current:2A
  • Logical Current: 0-36mA
  • Maximum Power (W): 25W
  • Current Sense for each motor
  • Heatsink for better performance
  • Power-On LED indicator
BOM (Bill Of Materials)
Schematics
Footprint
Top Layer
Top Layer
Bottom Layer
Bottom Layer
For the Gerber File, Follow and message us on
YouTubehttps://www.youtube.com/channel/UC8mQvRi15t0JOyzw6GYtnMA
LinkedInhttps://www.linkedin.com/in/technical-avant-garde-2761261b0/
Instagramhttps://www.instagram.com/technical_avantgarde/
Ordering the PCBs From JLCPCB
Full Process is shown using Screenshots Step-wise.
Now we have got the PCB design and it’s time to order the PCB’s. For that, you just have to go to JLCPCB, and click on the “QUOTE NOW” button.
JLCPCB is also a sponsor of this project. JLCPCB (ShenzhenJLC Electronics Co., Ltd.), is the largest PCB prototype enterprise in China and a high-tech manufacturer specializing in quick PCB prototype and small-batch PCB production. You can order a minimum of 5 PCBs for just $2.
To get the PCB manufactured, upload the Gerber file you downloaded in the last step. Upload the .zip file or you can also drag and drop the Gerber files.
After uploading the zip file, you’ll see a success message at the bottom if the file is successfully uploaded.
You can review the PCB in the Gerber viewer to make sure everything is good. You can view both top and bottom of the PCB. After making sure our PCB looks good, we can now place the order at a reasonable price. You can order 5 PCBs for just $2 but if it’s your first order then you can get 5 PCBs for $2.
To place the order, click on the “SAVE TO CART” button. My PCBs took 2 days to get manufactured and arrived within a week using the DHL delivery option. PCBs were well packed and the quality was really good.
