Accessing CPU Memory from Front Panel
A project log for 8 Bit Computer Front Panel
VHDL code for I2C Control of Front Panel with 32 pushbuttons and 32 LEDs
land-boardscomland-boards.com 06/17/2021 at 11:470 Comments
Created a branch which simulates controlling a CPU memory from the Front Panel. Made the memory an 8KB, Dual Port SRAM in the CPU. Able to read/write the memory.
It works!
Front Panel controls are:
The bottom 8 Pushbuttons/LEDS control d0-d7 of the SRAM.
The middle 16 Pushbuttons/LEDs control A0-A15 of the SRAM.
The top 8 pushbuttons control:
