I/O Processor
A project log for 8 Bit Computer Front Panel
VHDL code for I2C Control of Front Panel with 32 pushbuttons and 32 LEDs
land-boardscomland-boards.com 06/11/2021 at 19:390 Comments
Designed a custom I/O processor (IOP) in VHDL. Runs autonomously from the Host CPU.
8 Bit CPU Application
The 32 LEDs can be used to monitor
The 32 pushbuttons can be used for:
IO Processor (IOP) Block Diagram
IOP Features
Instruction Format
Assembler Input Format
CSV file with constrained input format. Header must match the example.
Compiler Input Format
First line WR001 compiles to:
Listing file:
I/O Map
