A revitalization using an iPod Video (5th gen) based off of the ESP-32 MCU, built on the shoulders of giants
The plan so far is to create an interface based on the LittlevGL library and a 2.4" 240x320 TFT display.
I hope to re-use the iPod's ClickWheel using the work of GigaHawk's ClickWheel Firmware, and eventually interface with the existing hold button and headphone jack
I'm hoping to work directly in C/C++ through ESP-IDF, as Arduino and MicroPython are too abstracted, and, if I'm going to learn a programming language, why not go straight for the gold with C/C++?
Would like USB-C support (both charging and data), and would like to use a Li-Po for the battery
A2DP support for audio out would be nice, and I plan on supporting MP3 and FLAC, along with AAC and OGG
There will be two SQLite3 databases: one for settings, and one for the library of music (which will need to be updated with artist, album, track title, etc. on a host PC)
I will go with LITTLEFS for the filesystem as (to quote the LITTLEFS project) "SPIFFS is too slow and FAT is too fragile".
At this point, I have determined the following:
- I will be using ESP-IDF
- I will be coding in C/C++
- The UI will be programmed using the LittlevGL library
- This will be based off of the ESP-WROOM-32 module
- My eventual goal is a working drop in iPod replacement PCB that can replace the internals of the iPod
- Flash storage with larger capacity
- Larger battery capacity for longer runtime
- Similar UI
- Working ClickWheel support out of the box
- Bluetooth A2DP support for headphones, car stereos, and speakers
- WiFi for transferring files to and from the device
- WiFi for Internet Radio (Spotify?)
- Support for MP3, FLAC, AAC, OGG (Lyrics? AlbumArt? Other Codecs?)
- USB-C support for charging and (eventually) data transfer
Evan Clements
CarbonCycle
hello this project seems like what I am trying to do but I am using https://forums.slimdevices.com/showthread.php?112697-ANNOUNCE-Squeezelite-ESP32-(dedicated-thread)
as the main part of it as it is already done and supports spotify deezer tidel youtube music and soundcloud, only problem is there is no local playback or ipod click wheel support so I am trying to make some code to convert the ipod click wheel into encdoder and button inputs to the esp32-a1s, and just have a separate esp32-a1s for local playback with a sd card
