It's glue time!
A project log for VT100 simulator and 3D printed replica
Simulator for the VT100 hardware. Running inside Gardi's 3D model.
lars-brinkhoffLars Brinkhoff 06/12/2021 at 18:541 Comment
I have now finished printing all the pieces of the VT100 body.
It's now finally time to start gluing the pieces together!
As you can see, it's a bootstrapping process.
I think I managed to get the pieces aligned quite well.  But this is only the raw material from which the final model will be furnished.  I have lined up epoxy putty and filler primer to smooth out visible joint lines.
Michael Gardi wrote 06/12/2021 at 21:30 point
Looks great Lars.
