Captains Log #7
A project log for Raspberry Pi Zero Prism
Pi Zero Prism is the upgraded version of Pi Zero Smart glass.Uses Image,Facial,ocr recognition,and browse Internet on it.
ricardo-ferroRicardo Ferro 12/18/2016 at 20:451 Comment
Updated and building another Pi Prism and I still have some experimental printed optical lens from form labs (just need to sand it with very fine grit ) also I will experiment with a smaller camera.
After that ill add another branch which the Prism will be built on the Chip Pro which is smaller than the pi zero. Most likely based on the specs i might have to order a chip module and design a board around it ( ;-;).
aBotSpot wrote 12/19/2016 at 08:31 point
Cool upgrade path.  I'll start to check out the Chip Pro
