I wired the socket for the microphone plus the neopixels.
The microphone bracket fit perfectly into the top part of the mouth piece.
The middle piece screw onto the top piece and holds the bracket in place.
I reattached the top/middle piece to the main phone part and everything fits perfectly.
With the mouthpiece cone screwed on you can't even tell there's anything special inside.
