Biscuit buttery base
A project log for Stock Ticker Machine
An old style stock ticker machine for the modern world
secretbatcavesecretbatcave 06/13/2021 at 11:200 Comments
Its time to cut the base. If you look at the hand drawn designs you can see that lots of attention is spent on making the base/stamping mechanism. I need to mill pockets to accept the solenoids and solenoid plate.
The great thing about having a workbee is that its trivial to cut wood with reasonable accuracy.
As good as the CNC machine is, it doesn't make up for user error, or my inability to measure.
The pressing foot is fitting really well
