workplace occupation state reporting system
declares the occupation state of workplaces, in this case for homeoffice action of two partners, protects against embarassing situations.
perhaps, at some point you have been in same situation - both at homeoffice your partner is in (conference) call, but you don`t know about:
"my daaaaarling....did you feed the cat today?"
"shut up, sweetheart - lucky i`m just on mute in a conference call"
"...oops, sorry...i don`t know about"
with this little tool, you can declare your state (with a fingertouch) and at same time get the state from partner within two coloured light stripes. communication is via 2.4Ghz (not wlan)
declaration:
  • light at left = partner
  • light at right  = yourself
color:
  • green = "could contact me anytime"
  • yellow = "hurry up, i`ll be busy right away"
  • red = "please don`t disturb"
x-zip-compressed - 2.98 kB - 07/03/2021 at 08:22
Download
Standard Tesselated Geometry - 4.37 MB - 06/14/2021 at 05:00
Download
Standard Tesselated Geometry - 770.75 kB - 06/14/2021 at 05:00
Download
AutoCAD DXF - 19.64 kB - 06/14/2021 at 05:00
Download
  • license
    snug07/03/2021 at 09:17 0 comments
    project license : Attribution-ShareAlike (CC-BY-SA)
  • software
    snug07/03/2021 at 08:28 0 comments
    • arduino sketches added
    as you can see, unfortunately i'm a very poor programmer, but luckily i almost always achieve the goals i need :-)
  • electronics
    snug06/28/2021 at 14:53 0 comments
    the electronic part is using only 3 pieces for minimalism so it`s absolute easy to connect the few (6) electric wires and usb cable for power supply (and or initial programming).
  • design
    snug06/28/2021 at 14:44 0 comments
    the cad-design was made with an older free Version (8) of Sketchup and exported to stl-file via free plugin. i wanted to have a nice looking but also useful housing for the electronics, which is what the molded part results from.
  • example video
    snug06/14/2021 at 05:05 0 comments
    sorry, only with german audio...but hey, no one needs this to understand the functionality  :-)
View all 5 project logs
  • 1
    lasercutted parts
    • for the top i used a lasercutted 3mm milky acryl
    • for the base plywood or mdf
    • for "light ring" template using thicker paper
  • 2
    3D printed parts
    • printed in pla without support
  • 3
    case
    only for nice looking, better haptical feeling and higher weight (125grams) my execution was done with a poured concrete housing together with printed 3D parts - this is a little laborious but of course you can 3D print all of the parts
View all 3 instructions
