I started working on this project out of nowhere and a little over 2 days later I had my own LED matrix glasses. It took a whole night to dry the epoxy glue mixed with black fabric color but, if I had some quick black epoxy the project was just a one-night project. If I go back and redo this project I will not use magnet wire for connections 😢 very bad decision!
This is one of the projects that I am very proud of because it required a lot of engineering and creativity at the same time. The first task was to devise a way to hold the LEDs in place at a specific distance (matrix) and the engineer inside kicked in to use graph paper and a piece of cardboard to create a perfect LED matrix. Then I used old spectacles frame and created these beautiful matrix glasses around them.
Deepak Khatri
boolean
Sergio Ghirardelli
Vikas V
ZaidPirwani
You're sexy and I know it too. Anyone who would make these is to me.
