Mounting
A project log for Cheap ROV Thruster
A 3D printed ROV Thruster based on the Blue Robotics T100 Thruster design and a cheap A2212/13T 1000KV brushless motor
tim-wilkinsonTim Wilkinson • 11/11/2016 at 17:37•0 Comments
My ROV projects are based on the ServoCity aluminum beam system (see https://www.servocity.com/structural-components/channel/mini-channel). As such I have adapted the mounting system on the Thruster to match the spacing of the beams.
Two bolts are slipped into the spaces in the main housing. These are a tight fit, but if they are loose you can epoxy them in place. The bolts are then passed through the beams and bolted in place.
