Nothing when energized? Let's dig in
A project log for It's evolving: Aiphone video intercom
Modifying an old video intercom to bring it up to the 21st century.
florianFlorian 07/06/2021 at 14:250 Comments
To confirm the power voltage of the display module and so the power generated by the step-down DC-DC regulator (LM2736YMK), I plugged the intercom to main power and did some measurements with my multimeter. I mainly focus my attention on the area where the display module connects to the mainboard, which is the following:
Unfortunately, despite the intercom being energized and being responsive when the front botton "通話/終話" was pressed, there was absolutely no voltage whatsoever in this area of the board. I thought something was wrong with my multimeter so I poked at the transformer and it's surrounding: my multimeter was working well.
So after this infructuous result, I decided to reverse-engineer the traces going to this CN101 connector and damn that was a lot of work! But it was totally worth it as I managed to figure out:
For more details, here is an image of the schematic I created but you can find the corresponding Kicad file in the FILES section.
My next course of action will be to simulate that circuit I didn't understand the purpose of and also see if I can connect that cheap 4.3" screen with double composite video input I bought quite a while ago. I hope it will be as easy as just connecting it to the mainboard video output to get it towork.
